Make : MERCURY Model : COUGAR Year : 1999
Manufacturer : FORD MOTOR COMPANY
NHTSA CAMPAIGN ID Number : 04V421000 Mfg's Report Date : AUG 26, 2004
Component: FUEL SYSTEM, GASOLINE
Potential Number Of Units Affected : 88600
Summary:
ON CERTAIN PASSENGER VEHICLES, CONTAMINATION OF THE FILTER IN THE FUEL DELIVERY MODULE (FDM) CAN REDUCE, AND EVENTUALLY BLOCK, THE FLOW OF FUEL TO THE ENGINE.
Consequence:
THIS MAY CAUSE ENGINE HESITATION, LOSS OF POWER, SURGING, AND OTHER SIMILAR SYMPTOMS. OVER TIME, THE FILTER MAY BECOME SUFFICIENTLY BLOCKED TO CAUSE THE ENGINE TO STALL, WHICH COULD RESULT IN A CRASH.
Remedy:
THIS ACTION IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN AND IS NOT BEING CONDUCTED UNDER THE SAFETY ACT. ALL OWNERS WILL BE NOTIFIED OF THE PROBLEM, AND DEALERS WILL REPLACE THE FDM WITH A NEW DESIGN AT NO CHARGE IF THE OWNER REPORTS THAT THE VEHICLE EXHIBITS ANY OF THE IDENTIFIED SYMPTOMS. THE FREE REPLACEMENT WILL BE AVAILABLE FOR A PERIOD OF 10 YEARS FOLLOWING THE ORIGINAL PURCHASE OF THE VEHICLE, WITH NO MILEAGE LIMIT. THE CAMPAIGN BEGAN ON APRIL 16, 2004. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673.
Notes:
if i am having the same problems with suirging, loss of power and hesitaion, but the dealership wont cover it under recall. stating it not listed as neeing a recall.
is there anything i can do?
Text
Summary:
Consequence:
Remedy:
Notes:
Text
