Yes.
You see that little hole just to the left of your fuse block? You need to cut a hole there - about 80-85mm. this puts the Air Filter behind the bumper and in front of the wheel. the precise location will be determined by your kit, as you install it.
In this pic, you can see the same hole...just to the right of the down tube. this is looking toward the bumper from the wheelwell...with the inner fender taken off.
