Well, you could rent an engine lift and pull the entire assy, but that really is much more "involved" than it needs to be.
After reading the replies at work, I asked both transmission techs and the shop foreman what they thought. They all agreed, pulling the entire engine from the top to change the clutch and flywheel is 10x harder and more "involved".
If you have access to a lift and air tools, you can do the swap in a matter of hours. Remove the wheels, drop the subframe, remove the left axle, drop the tranny. Set the tranny on a bench and replace the clutch, look up and replace the flywheel....reverse. I am planning on doing mine in a few months, because I know the clutch is going....and while I am up there I am going to replace the flywheel because I have access to an SVT one for free. I have access to a lift and all the air tools I need, as well as techs to help me if I need it. It should not take me more than a few hours....most likely I will take all day long because I tend to goof off a lot.
If you remove the engine from the top, you will still need to disconnect the engine and suspension from the subframe, as well as all lines, fittings, and what not. Then lift the entire engine/tranny/axles/ect in one assy, THEN disconnect the tranny from the engine. By going from the top you will spend twice as much time as needed. True, it would be the easier way if you have no access to a lift, as you will not be able to drop the tranny while the car is on stands. But to be honest, if you don't have access to a lift, and you don't have a week to go without a car, I would not attempt it yourself.
