1 - 12 of 12 Posts
Hey guys, I looked up injector colors and all I can find out for sure is that the 19# are green for the returnless. Anybody know what color the 24# injectors are for returnless or a way to tell for sure what pph (#) they are for sure?
I have #19 which are green and are return style..... :confused:
okay,
who can answer this question...
this injector in this picture is???? :confused:
(mind u it came of a 3L 2002 sable)
its says YL8E-C7B on it
would u consider this cream, grey, or white?????????????????????????
most importantly.... what is the poundage???
As I posted in your other post I had the cream and gray injectors from the 2001+ sables/Taurus flow tested.
Flow Test Results:
Cream:19lb (the ones you have in the picture above)
Gray:22lb
SVT Contour Orange:19lb
I was expecting the cream injectors to be 21 and the gray injectors to be 24 so it was a bit confusing. After running the orange injectors which we know are 19's it verified the tester was working correctly. Also the tester flow tested 6 injectors at once so we could verify it wasn't just a bad injector . All the injectors in each group were very close to the same flow rate.
whewwwwwwwww.......
alright,.. thanks for the info and clarity...
why would a 3L come with 17#s... as long as they were 19#ers that was my concern all along.... so we are good to go... :thumbsup:
This engine goes in this weekend :)
1 - 12 of 12 Posts
