Well, err, I guess that's what you'd call it. I had a little extra time and finally finished the install on the kit. Last night I changed my spark plugs to a copper core 1 heat range colder with a gap of 0.40". Took me about 45 mins to do that as it was pretty straight forward. I also had to the run main bottle feed.
Today I went and got the bottle filled at Summit Racing. Cost me $50 at $4.80 per pound. Ouch. I will have to look if there are cheaper sources. I got back, installed the bottle, and opened the valve. Checked for leaks and didn't see any frost on the connections. Tried out my purge valve...hehe...I will probably end up wasting more that way because it's so cool to see it shoot out right in front of the windshield!
Anyways, I tried out the 55hp setting for a couple of runs...mind you I have an ATX. From a standstill it was pretty good as I actually put down some rubber. I was kind of surprised because I've got TSW HockR 18s and BFGoodrich Comp T/As and they have alot of solid tread contacting the pavement and but aren't the lightest rim.
I went back and put the 75hp jets in and went out. Tried again from a standstill and got some wheel hop and good pull. Hard to find decent flately paved roads around here so it was kind of rough. If I put my 16s back on they probably wouldn't last long.
During this whole trialt I had been listening for detonation/pinging and didn't hear a thing. I had no problems, nothing out of the ordinary happened, and really think the 100hp jets are in order.
Definately a 10 out of 10. Possibly even higher for us with the automatics since they are so sluggish and you can't install a supercharger.
