Guest
·OK....I had to take my shifter off to finish putting my dash on. I had a really hard time pulling it off even after I removed the little screw thingy on the side. I pulled and pulled then it came off kinda half way...then i pulled and pulled and pulled some more then BAM!! It cam flying off but there was a green and black wire hanging from the shifter and a green a black wire coming out of where the shifter goes in. I know I didnt break the wire b/c the ends were cut even and it was even stripped a little on both ends. And I saw where they were right when it popped off and they werent even on the same side and its impossible that I could break a wire a apart. I cant even open a soda bottle. So obviously these wires were not connected. What the hell do I do now, I have no OD...well OD is stuck on. And I am using a metal rod for a shifter. Theres no way to get into the shifter to fix it so do I have to go to the dealer?? Or maybe theres a possiblity that I can just relocate the OD switch, that might be easier and cheaper. Anyone have this hapen before or know what I can do? I need help ASAP because I have my first car show this Sunday and they frown upon cars with no shifters
~~Thanks
~~Thanks
