Guest
·Ok... i have gone through many hours of research and many pots of coffee and still have a few questions. I have read EVERY post on this topic *that hasn't been archived*
I have access to a 2003 Escape motor with only about 5k miles on it. my car is a 99 and was built early that year, i do believe i have a return fuel system if that matters. I know the benefit of putting in a hybrid is higher horsepower and a higher compression ratio- but from what i've read, a straight swap is much easier to pull off.
With a lower compression rate out of a stock 3, wouldn't this be better for running a turbo than a higher compression hybrid? Or am i totally mistaken and ill informed?
Also if i used the 03 Escape motor, and did a straight swap, what mods would have to be done? It should just be longer hoses for hookups, correct?
How many pounds are the injectors in that motor?
Would i still need a new chip burned? also, what processes are involved in that? would i have to take my car to streetflight? or what?
Thanks for any help- and please don't grill me if these have been answered before- i really want a three liter, however, my motor is not suitable for a hybrid, so i'm looking for cost effective, and what will leave me without a car for the least amount of time. I have been researching this since i bought the car and finally have access to the motor and the money to have my shop install it... thank you again for any help!!!
PS- Is there anyway to set the odometer to the mileage of the engine i am installing- for ease of remembering to have routine maintenance performed, If i got a new computer, it would reset the odometer, and theoretically, i could run up the new mileage to match the mileage of the swapped engine, correct?
