Hey to ALL!!!
How are you guys doin today?
Well, I'm posting this because, quite Frankly, I need Help.
Well, I'll give you the information and then ask what you think I should do with it.
To start, I have a Complete Garrett T-25 Turbo from a 97 Mitsubishi Eclipse GST that I helped my buddy take off of his Eclipse because he put on an upgraded Garrett Turbo and Boost controller and what not. So I opted to take the old turbo off his hands because the thing needs to be rebuild. Not a full rebuid, rather only a simple rebuild kit off Ebay would suffice perfectly as the Compressor shaft has a very small amount of play in it. A new set of bearing and a Really good lube and I'll be all set to go.
Now, I am VERY knowledgeable about the entire Turbo setup and how to do it, But what I am NOT very knowledgeable about doing so to our 2.5L Cougars and I'm comming to you guys for answers.
I work at a machine shop and my father happens to be the Vice President of the Company with a FULL powdercoating facility also. If anyone needs any custom work done. I can have it done for you for cheap, just so you guys know.
Well, my first question is this: How do you guys normally install the Turbo seeing as how we have "V6's" with 2 Exhaust manifolds and its not as easy to install a Turbo as it would be for a Single exhaust manifold on a 4 Banger. You see where I would have a question? I scrolled through a couple threads to get an answer but I didn't quite find the info I was looking for.
My next question is, in order for the Turbo to work properly it needs a great cooling line filled with pressurized OIL. Well...Where do I tap into the engine to get nice Clean, pressurized oil to supply the lubricating system on the Turbo? And after that is answered, there are a few different places to route the Oil Return line but where do you guys normally do this and/or where is the BEST place? I Understand this is an arguable thing but I need some options if you guys could do much as to help me out here please!
Another question is, Do I run the intake tubing off of the compressor housing directly into the Throttle Body while still going through all the stock parts that the filter would ordinarily connect to, like the MAF sensors and what not.
Should I even bother with using an InterCooler? I am capable of making something that would act like an intercooler to cool the compressed air very well also. I could also just buy an intercooler off of a turboed car from a junk yard or something. I have a hook up at a salvage yard to get good parts for cheap also.
Now for my ideas: I was thinking that I would Take the Turbo and run it off the Exhaust Manifold on the Front of the engine facing the front bumper sorta place. I figured if I take the Stock Precat off and run the Turbo in its place, it will in essence, create a little back pressure in the absence of the HIGHLY restrictive Precat, and leave the CAT on the other exhaust manifold so the backpressure it fairly equalized. That sounds like it would work good. But if someone knows a better way, PLEASE let me know how you do it!! Run my Pressurized Oil coolant line from possibly the oil Filter using an adapter, run the Oil Return Line into the Oil Pan. Run a Small Intercooler(If I even Bother to use one at all seeing as how all I want is LOWW PSI...maybe around 4-6psi Tops since its Stock internals) and use a basic Blow Off Valve, maybe from a older DSM like a 91' Eclipse GSX because they have metal B.O.V.'s capable of holding around 20-25psi Stock but I would need nothing close to that power, I would only use it because they are build Tough and I can make it adjustable.
Alright, that just about sums it all up, from what I'm working with to what my Ideas were. Please leave suggestions if you have built the turbo kit before for my car. If you havent built a kit before and your only offering useful information, thanks, but I'll tend to listen to someone that has gone through this before. Thanks for your time and effort in helping me out everyone!!!:biggrin:
