Best to remove the manifold. You don’t want to knock that crap down inside your cylinders.
There’s a good how-to in the how-to section for manifold removal/replace.
Also if it's available try using non ethanol fuel it'll help with carbon deposits. At least for me in northwest corner of florida.
EGR and ****ty oem PCV oil/air separator are to blame.
Can take it off and scrub it in parts cleaner, sand blaster works nice too.
Pcv is pretty cheap to replace and pretty easy as well being under the air filter and hose. Egr is slightly more difficult due to the exhaust pipe nut/flare running to the manifold being more than likely seized up due to oxidation.
Not on a 2001 - the PCV is a non-serviceable unit located in the valley between the heads. You have to remove a cylinder head to R&R.
If your not ready to pull the lower manifold for cleaning right this minute, you could do an aggressive seafoam treatment which might help some.
I wouldn't stress out about the EGR and PCV. Unless you're sucking excessive air or getting EGR codes, they're probably working as designed, that gunk just builds up in there during normal operation.
I'm going to be installing an oil catch can with my build, 🤞 it will prevent this from happening
