well... you cant hear it, or if you can, it sounds like S**T. thats the easiest way. it'll also smell/smoke when it blows usually. but yea, it just plain old dont work right.
If you push on the cone and you hear scratching from the coil, thats not good. Or if the cone does not move freely.
And smell it- best tactic, you never know how good something is untill you smell it...the subwoofer....ok back on track.
The stink of electrical burns is a sign of coil damage.
Well its blown then :(
Thanks.
when i had 2 much power 2 my jl 10 before, that thing was rock solid. my friend punched it and hurt his hand.
the 100% way to check is get an ohms meter...... put pos to pos and neg to neg from the meter to the sub.... push on the cone once or twice and let it come to rest..... if its good it should read about 4 ohms (for a 4 ohm sub) if not, then its blown
my friend had two lightning audio subs (got 'em for free with a RF amp), and one of them is kid of sucked in towards the box. You can push it in a little and it makes a loud scratching noise. Pretty odd tho, like something was reversed and it just got sucked inward.
That sounds like coil damage. The voice coil may be bent around the pole in the motor structure, that is caused by a loose magnet or stressing the cone past the x-max.
In other words is screwed.
