1 - 14 of 14 Posts
How would I prevent the moonroof from breaking on my 01 Cougar?
I know its a common problem due to the plastic parts and its apparently expensive to repair...
I dont want to be stuck in that corner, how do I prevent it breaking (while still being able to use it in the summer and what not).
w00t!
Thats what I thought... but I was talking to Ron (excelcier) who went through the break...and he said theres some kind of plastic thingy (technical term :tongue: ) that is the culprit - when it breaks, it prevents the sunroof from closing, and its on all cougars regardless of metal tracks (for 99's at least)
Cause I had metal tracks... and was pretty much told by a few people at Hamillfest that it didn't matter :(
Don't use the sunroof - take no chances ( ha ha ha)! I got a good used one off ebay a while back - replaced it myself - and saved much moola - total was about $220 - I only tried it to see it work - and it does - I tested it again later - never use it while driving - I guess the wind pressure is part of the problem - plus of course the weight of the sunroof itself - thats my best advice - save it for selling the car and warn buyer - its just for looks and thats it!!
Discussion Starter · #9 ·
why didnt you just replace the plastic parts with metal parts right before you installed it? :confused:
The failure point is not always the tracks, but a small resin gear. This is not a part they can make metal, and it fails constantly -- totally stripping itself and causing issues just like the bad tracks.
I had a metal track roof that failed, so I dissected it to find small plastic-like shards all over inside.
E1
Discussion Starter · #11 ·
E1
So lubing it wont help?
El Mucho Post Whoro
E1
That's how mine went. Was closing my sunroof one day and heard "CRACK".
Dissected it and found one of the resin-cast "legs" on the sunroof went bye bye.
I agree, once i get mine replaced im NEVER opening it again! haha too scared!
Honestly, what E1 said is right, I had a busted plastic track, replaced it with a metal track and the part that broke on the plastic track is also still plastic on the metal ones. Quite simply, our sunroofs are an a$$ design... if you don't want it to break, stop using it. Direct and to the point!
I replaced mine, opened it once to make sure it works, then closed it. Never to be opened again. I'm thinking about pulling the fuse to avoid accidentally opening it.
1 - 14 of 14 Posts
