i did a search and couldnt find anything...so does anyone have a write up done...or some suggestions..any help would be appreciated
thanks
jared
Discussion Starter · #2 ·
yeah dont do it ..
i had a lot of trouble taking mine apart, but if you are to do it, its pretty much self explanatory once you get to it.
i had alot of trouble removing the rear of the assembly that held the bulb and wirering, i suggest you try to take that of before you remove the clear plastic lense.
i did it on mine was simple as the headlights if you ask me basicly the same steps
