I use the pinch welds to jack up the car
yet my jack cant reach the inner frame...also main supports correct?
How am I supposed to put the front on jack stands when the pinch welds will
be doing the jacking?
i always use a floor jack and jack it up by the front subframe, right in the middle. then slide jackstands under the factory jack points. longest period of time i've had it up there has been about a week and a half...
uRiDiAN
ok thanks
is the subframe those 2 angled pieces of metal with tiny holes in it,
right along side the pinch welds...kinda where the drivers feet are etc
If you slide the jack underneath the front of the car...that's the best place I've found...even works with my Dragon-Z (not slammed) If you roll a good floor jack right under the middle of the front and find the subframe there, you can get it up pretty high...always works for me!
