how do i do this. i have put new pads in and they were sensorless. how do i disable this light?? i did a search but found nothing
Or you could just leave it be so you'll have something to aesthetically balance out the inevitable CEL.Originally posted by: sugercoatedcougar
Which (common sense) eliminates the code in the computer... poof no CELOriginally posted by: mond12345
Heres something a little better to understand!
Easy fix if you still have the stock pads around. Take the plug from the pad, cut it off the old pad and take the two wires and wire-nut or solder them together basically to complete the circuit and shut off the light.
:bs:Originally posted by: tr0nic
You don't pop a cel from brake pads silly.
Maybe your just special?Originally posted by: ice992
Ive got one right now b/c of them... i forget the code
