I'm posting this because I think it needs it's own thread, so many people are confused by what happens when the antenna breaks off, and also people are paying up to $150.00 for a dealer to fix it which is ridculous. So here's what's happening and how to fix it...I promise this is correct, I went through this from the moment I bought my cat.
First of all, if your antenna snaps off and it looks like there is a metal spindle broken off inside the black base, don't be confused. This is not a piece of the antenna mast. This is a part of the base itself. The black base that is attached to your car has a metal spindle that sticks out of it. This makes the antenna base male. The antenna mast then screws onto this spindle, making the mast female. A lot of people think that what's broken off in the base is part of the mast that screws into the base, but it's actually opposite of that, the antenna screws onto the base.
So if this happens to you, don't bother trying to drill-out the piece that's inside there. That will leave you with nothing but a hole in the base, and then the antenna has nothing to screw onto. Basically you're left with two female parts that won't connect. Now if the other half of the spindle is stuck inside the antenna mast, which it probably is, drill that out carefully to save yourself from having to buy a new mast.
The only way to fix the problem is to buy a new base. This is where it gets tricky, because apparently from what I've heard people are paying like $90 or more for this piece. Go to fordpartsonline.com, the piece is around $36.00. It is called the base or the bezel. You will not need the cable and you probably won't need the mast (unless it snapped in half too or you can't get the remaining piece of the base out of it).
Once you receive the new base, you will see the spindle is part of the base and this will make sense to you. As far as installing the new base, I beg you not to take it to a dealer and pay for labor because it will take you 10 minutes to do yourself, and it requires nothing but a torx wrench and a small flat-head screwdriver.
Get inside your car, and carefully remove the plastic trim square that surrounds your dome and map lights. It just pops out with the use of a small, flat-head screwdriver. Once you get that out, look into the roof and you will see a wad of foam. Remove the foam. This will expose the antenna cable. It has a torx screw that attaches to the roof. Use a torx wrench (I don't remember what size it is) and unscrew this screw. Once it is loose, make sure you don't allow the cable to fall down into the car. Once the screw is pretty loose, get out of your car and you'll find that the base on the roof is loose. Just twist it the rest of the way off. Then take the new base and position it where the old one was on the little spindle coming through the roof from the cable. Get back in the car and tighten up the torx screw on the cable. Put the foam back in the hole, snap the trim piece back in, and screw your antenna mast onto the new base. You're done, and you save yourself $$$$!!!!.
I hope this clears this issue up from now on, I know it's confusing because I thought the piece broken off was the mast at first too. The bottom line is that if this happens to you, and it's common because of the design, you have to replace the base.
Is it just me, or is this repair a little naughty to describe?
Oh, I'm sorry if I seemed to have an attitude when answering this for other people in other threads, that wasn't my intention, but this point is really hard to get across this way and I don't want people to do extra work they don't have to and then realize it got them no where, plus I can't see paying as much money as some people said they did to have this fixed. This is definately a do-it-yourselfer.
