Guest
·The other day I went looking all over town for a Foam recondition. I was finally pointed to a motor cycle shop. I asked this woman at the desk and she tried to give me the K&N recondition stuff. I said that I didn't think that would work because it's made for cotton/paper filters. She told me to hold on and she went and got some guy from the back. I think he was a rep. from some company, I'm not sure who? He was dressed up. He said not to use the K&N.
He said to clean the Weapon R filter like this:
Take the filter and rinse it off in the sink. Make sure that you're carefully with it, because it's thin and fragile when it's wet. I rinsed it from the inside, out. So that I didn't push dirt into the filter, I pushed it out! He said let it dry and not to do anything until its completely air dried! It took mine about 24 hours.
Then he said use WD-40!!! for the oil! He said NOT to saturate it! Just spray it down to prevent it from drying out! I applied several light coats inside and out! He said that the filter does the work, not the oil! It's all clean now and seems to work fine!
All in all... IT WORKED.... IT WAS CHEEP... AND IT WAS EASY!! Just like I like it!
Disclaimer: If you do this and it screws something up, it's not my fault
