For instructions you can follow the dash removal how to and then when you get the gauge cluster out and out of the car you will pull the face off Do NOt remove the needles the hole plastic layer that the needles set on will pull off or you can follow the instructions here click here but instead of useing the taillight repair tape I found the colored window tint works beter than the repair tape and this way is cheaper then the lcd convertion kit from cc if you have any questions let me know I will try to get some pics asap
