If you've tried installing a performance chip in your car and it would not start, this could be the reason. I was informed by a fellow NECO member that some late model 99's and all 2000 Cougars' ecu "ports" are not activated. Well, it turns out this was my problem. I tried installing a Diablo chip and the car would not start. It would turn over but the check engine light would flash and it would not start. So after some research, I found that you could activate the port yourself. Here's what I did:
Before you do this, make sure your connections are clean and try it again. If it still doesn't work, this could be your fix:
Take out the ECU, open it up. There are four small "contact points" (I have no idea what they're really called) that need to be connected. Actually, you have to connect two pairs separately. Refer to the attached picture. Make sure get the clear plastic coat off of the area first with some sand paper or a scocth brite pad first. Now these "contact points" are <u>really</u> small. My first idea was to solder a piece of wire between each point, but because they're so small and close together I just soldered them together directly. (Actually a friend of mine did it because I know nothing about soldering)
And voila! Car fired right up!
I hope this helps some of you.
I found this info here.
