1 - 13 of 13 Posts
are you the one that picked up my diamond plate matts at fest? if so, heres a list of all the things that WONT work (everything that i tried)
-soap and water
-Gojo and water
-Ajax scouring creme
-Flitz
-Noxon metal polish
-PB Blaster
-WD40
-Liquid Wrench
all products were used with a wash cloth and also a brillo pad (you know, green scratchy pad thing) and scrubbed for long periods of time lol. and i think there were one or 2 other polishes that i used that also didnt work. and i was running out of things to try, hence the 3 rust removers and such at the end lol.
Use heavy duty degreaser and then polish. That [censored] cleans EVERYTHING... I cleaned a daimond plate floor piece at my work with it and the thing had 2-3 years worth of [censored] caked on it. Make sure you wear gloves when you use it though, it eats up all the oil on your hands.
They best way to clean them if they are Aluminum is to use a 50/50 mix of vineger and water. This mix is also good the help clean the Valve Covers and UIM that are aluminum.
1 - 13 of 13 Posts
