1 - 2 of 2 Posts
How much harder is it to do the back rotors and brakes than the front. I have heard stories and want to verify them.
Also, the person that said 71k for brakes and rotors must not take full advantage of the DURATEC Engine.
· is a pop sensation
The setup it a bit different, but the rears are not much harder than the fronts. Just remember that you don't use a clamp to compress the rear caliper piston. You'll need to take a pair of needle nose pliers and rotate it clockwise to get it to retract.
1 - 2 of 2 Posts
