Same here, it rubs just slighty on the passenger side. It was really easy to install. Just place it where you want it on the strut towers, mark you holes and drill.Originally posted by: Bennett9000
Mine touches the hood a little bit on the passengers side, and it will eat the EGR fitting - you can trim that down a little with a razor blade to help it to clear.
Yep, I think I would have to agree with the both of you. I actually cut down the EGR boot and took a a round file and filed down the strut bar a little for extra clearance. I think I need to invest in some solid roll resistors.Originally posted by: MaverickFlyer
Same here, it rubs just slightly on the passenger side. It was really easy to install. Just place it where you want it on the strut towers, mark you holes and drill.Originally posted by: Bennett9000
I used a vacuum boot from a Vulcan V6 (I got a handful free from a junkyard), which is a good quarter of an inch shorter than the Duratec one, and I have no clearance issues now. I also have a front motor mount insert...Originally posted by: jrak123
