I just got the E-brake handle from customcougars.....it was surprisingly HUGE first of all.....secondable....I can not take off the original factory E-brake handle...can anyone help??? thnx
Discussion Starter · #2 ·
If it's anything like the Contour e-brake, pull back the e-brake boot a little bit and you will see a rivet on the driver's side of the handle. You'll have to drill out that rivet and then simply slide the handle off.
Mind you, that's how a Contour is, I don't know for sure that it will work on a Cougar but it's worth a look!
HTH
here's what I told someone else... it's alittle more detailed...
link
(sorry for the yellow hightlights... I did a search to find the message)
