Ok first, you should check on contour.org for a used bat inlet pipe or cta inlet pipe...
these are good replacement units...I used the svt accordian tube which is larger than stock.
If you want to make your own, buy some 3inch or larger piping from home depot/hardware store and add some "nipples"
to it for the hoses/vacuum lines, but can be time consuming since you will have to drill in plastic nipples and make sure they are the right size, etc.
Then buy a K&n RC-4630 or similair sized cone filter...40 bucks will get a very large filter.
Lastly, you will need a maf adapter if your using the stock maf...spmotorsports.com sells them, duratecperformance.com,
etc.
