How do I remove, driver's side front panel *over wheel well*
I had a slight acciendent with a basketball...
Just the sight of it hurts :disgust:
A dent right behind the left headlight over the wheel about the size of a vollyball just screams at me everytime I walk by. I'm a bit broke just moved to cali so no $$$ to drop at a shop for them to band it out. Anyone have any pointers before I just dive in tom, picking screws and nuts as I go along to get the fender off and tap the dents out with a rubber mallet....
any tips appreciated
If I remember correctly there is like 3 or 4 screws right under the hood........and a couple right behind the mirror cover thing.....and ....ummmm I cant remember where else :biggrin: :shrug:
Buyer Beware
i just did this the other day.,
remove your hood. its easy 4 bolts. (you dont want it to fall on you while you work)
top:
remove all bolts on top of the fender.
remove fender liner. total of 5 or so bolts.
right:
there are 6 remaing bolts holding the fender on. 3 on each side.
2 on the right hidden behind foam sound material. (hidden inside fender behind turn signal)
1 on the bottom of the fender (directly under the turn signal
left:
2 bolts attach to the bumper to the fender and one more hidden inside which attaches the fender to the fram
