Guest
·My cougar (2.5) has just failed its MOT (Annual road worthyness test in the UK). It failed as the parking brake was not effective on one side. I have changed the caliper, although on further investigation it appears the cable also needs changing on the same side.
The cable disapears behind the heat shield (between floor of car and exhaust) This in turn appears to be bolted from inside the car. I do not want to strip the car for nothing! Does any one know if this is the only way? Has anyone else had to change there cable?
A Confused and Despreate Cougar Owner!
