How do I change fog light bulbs? Search failed!
757 Views 5 Replies 5 Participants Last post by  NARD
:confused:Sorry for being so rubbish but any how to's on changing my fog light bulbs on my '99?
there's that little "trap door" in the lower grille. open that, it will expose i believe, 1 screw, take that out, pull the housing out, pull the bulb out, replace it, repeat backwards
You can also take the splash guard off (7-8 screws), and you'll have direct access to both lights... I think you need to do this to access both sides, anyway.
I just did this.
Remove trap door. Remove one screw. Pull lamp housing out far enough to reach wiring harness. Unhook wiring harness (it's held on by a clip. so you may need a screwdriver). Remove foglamp assembly entirely. Pull rubber cover off the back of the housing. Unfasten spring-clip holding bulb assembly in. Take out the bulb, socket, and "pigtail" wire connecting to it. Unplug the wire pigtail and the whole bulb & wire piece comes out.
That's about it.
That's just on the 01-02's... the 99-00's are lucky enough to have two trap doors.
:biggrin:Thanks all. I'll have a go this w/e and let you know how I get on.:grouphug:
