I've had a rubbing noise for quite some time now when I drive. It comes from the front and used to only come in when taking a left turn. Now I have it when taking lefts or driving straight and it completly dissappears when taking a right.
It's not shaking the car, but more of causing a deafening drone that sorta "shakes" the dash...more like the feeling of humming and putting your hand under your jaw...but loud. I recently took off my summer wheels & put on the winters. The passenger side wheel was worn to the belt on the inner wall, which is an alignment issue...
When I took it to a dealer for them to ask what might be the probable cause describing exactly as above they said they would have to put it up (and charge $$ of course) and take a look because it could be an Axle, CV Boot, Tie Rod or Bearing. Weary of this I declined for the moment (I had to be at work too).
My question is how can you tell if your having a problem with wheel bearings as opposed to the axle? What side would the problem be on if the drone goes away when taking a right turn? I'm looking to go in with the most knowledge so I can say "I need xx on the x side of the car replaced."
