1 - 3 of 3 Posts
Tonight I am pulling a couple engines... one from my cougar, one from a 97 contour, and one from a 98 contour.
Where are the stock engine hoist locations on the block to hook the chains up to? I understand I need bolts to attach the chains to, where do these go?
If someone could provide a picture with a couple arrows that would be excellent. Thank you everyone!
i used the loop on the one side and the upper mount on the other. i either wrapped the chain around the mount or i sued the huge nuts and studs. either way will work. the slight problem is that it will tilt slightly, but you need to tilt the motor anyway to pull it.
El Mucho Post Whoro
++ What he said.
I used the nuts on the passenger side upper motor mount to hold the chain down, and I hooked the other end through the metal loop on the driver's side near the IMRC.
1 - 3 of 3 Posts
