I just tried to install my aluminum fuel door and could not find all the plastic "clips" that hold the damn plastic cup in. I am by no means "automotively inclined" so any help would be appreciated. I found the two bottom clips but I have no idea where the other are. HELP!!
I saw a thread a long time ago in the how to section on the fuel door install
you got to look back
good luck
T3/T4 60-1
teamneco.com has a full blown how to with pictures for this
Remove the 10mm bolt holding the metal fuel tube, that will make it drop a few inches.....then you'll have some working room. If you use a screw driver to depress both bottom clips......then push that side of the cup up, you'll get the whole cup to come out.
I did my install last night...it wasn't that bad. Thank god for Dremel.....:bowdown:
It looks great! Good luck on yours!
Thanks for all the help. Afterhours that is exactly what I was looking for. I'm gonna try it again this weekend.
