if you want to change the color of the info/clock LCD screen all you have to do is open up the Gauge assembly....remove the black plastic clips holing the LCD down. then use a razor blade and pull the green plastic screen from the LCD glass.
You MUST take extreme caution. look really really close before you start cutting. you will see that the green/white screen is on the bottom. its about 1mm thick. thats what your removing...once its removed...sand or use the razor blade to scrape the "green" off then either paint it with a clear candy coat or use colored cellophame of your choice and BINGO! colored LCDs.
The cool things is that if you use an overhead projector clear sheet with a printed image that image would show up on the LCD screen when you turned your lights on.
