Hey guys, i'm new here. The situation is, I have a 2001 Mercury Cougar V6, Automatic, original ownwers and its my sister's car (58000 miles). Just a couple weeks back, the check engine light comes on. My trusty mechanic tells me to run the A/C less, because the car is getting too hot. Just today, I took it to my local Ford dealer, for diagnostic and confirmation of my mechanic, and they tell me the codes they get (P0741 & P1744) are for the transmission and they found transmission fluid and oil leaks. Also, in the morning, or before the car warms up, I've noticed that the car will not fully engage in reverse. Its as if the car, in reverse, goes in neutral for a few seconds, then all of a sudden shifts into reverse and the car will move, then it will go into neutral again, only in the morning. Its almost as if its hesitant or something, but if I push the gas pedal, it'll just rev and when it finally engages it'll move. FYI, we had gotten the tranny rebuilt by our mechanic when it started slipping, less than a year ago, or he might've installed a rebuilt one, not exactly clear on that (46000 miles). Seems that it is barely within the 12000 miles warranty mark. I haven't had any other real problems with the car, except for the fuel pump campaign deal and for some reason the door handle doesn't spring back in place, and that has to get changed and we otherwise love the car. So, I want to know exactly what the codes mean, P0741 & P1744. It seems that the tranny on this car particularly is a recurring problem, or is it on a lot of Automatic 99-02 Cougars...? After I get it fixed, would you guys recommend selling it, or should I keep it. It will be payed off next year, but we don't want this problem coming back, or want other problems as the car ages. My sister drives all over the place, and this is sometimes why I think this car develops such a problem, but otherwise its not like it is driven very hard, just extraneously. Any techs know what might cause the problem and if I should repair the trans or get it fully replaced? And also what I should do if I do plan on keeping the car in good shape, especially with a costly item such as the transmission. Thank you in advance for your advice. I will also post this in the transmission thread area.
