Guest
·Before I start pulling things apart, does anyone know where the cable connections are likely to be on a heated front windscreen.
Is there a connector each end of the windscreen? I intend fitting a heated screen to my cat, but I am looking for all the loom first. Should I start looking under the dash or from under the bonnet?
I have found the wiring behind the dummy switch, also where the relay should fit (but ain't there) and the fuses (which are in situ).
Thanks Vernon.
Thanks Vernon.
