Ya there is a light behind that knobber.... you have to pry off 2 bolt caps on that panel under the steering wheel, then remove those 2 bolts... and then the 2 screws holding that headlight plate up.... pull it down and you will see your little 12V bulb.... turn and replace...
its easy....
