1 - 2 of 2 Posts
if you look down behind the light assembly, you will see two protrusions, that have slotted screws in them. there are two per light assembly, one aims vertical. the other aims horizontal. also there is a level built into the light that you can level the lights out with. Adjust the vertical first, then the horizontal, if you flip that order, you'll screw up the alignment. look in your manual under headlights for more info.
You can just reinstall the entire assembly. First remove the upper grill, then the three screws holding in the headlamp assembly. It may not have been screwed in properly or completely.
1 - 2 of 2 Posts
