Originally posted by: Massiv
Hey... can someone give me a rundown on the negatives to this, or can I please hear from the people who have LOST power by doing this? Why is more backpressure beneficial for torque down low anyway?
Massiv.
Technically, it is not backpressure but exhaust gas scavenging that is beneficial.
If your exhaust piping is too large or if the main catalytic convertor is gutted, e.g., it's a big empty chamber, the exhaust gas flow will slow down, cool (cold gases flow less efficiently than hot gases), and the pressure that "pushes" the exhaust gas through the exhaust system will lower. All this leads to less efficient removal (scavenging) of the exhaust gas. Think of how a given volume of water flows with higher velocity through a 1-inch hose verses the same volume of water flowing through a 4-inch hose.
On the other end of the spectrum is that too small of piping and/or restrictive mufflers etc. don't let the exhaust gas escape efficiently because of high backpressure.
The trick is to maximize exhaust flow/scavenging but not going too far so efficiency is lost.
A Cougar specific questions is whether gutting the three way catalytic convertors/manifolds (precat) will allow the exhaust gas velocity to slow down enough to actually have a overall detrimental effect? It seems because the precat is so close engine (where gas pressures are highest) and the size (empty chamber) is relatively small compared to a main catalytic converter, this may not be an issue?
Does anyone know for sure by having before/after dynometer results or something?
