S
SportinStyle
·Guest
I was just wondering how easy (or hard) it is to raise and lower the body. How do you go about doing it?
Thanks!
Thanks!
Originally posted by: PuckPuck
you jack up one entire axle at a time (both fronts or both rear wheels).... then you take a 3/16" allen key and loosen a bolt on the perch of the coilovers..... spin the perch to desired height.... tighten allen key.... repeat on other side.... that's it....
btw: if you try to do one wheel at a time you will have problems from hell... you need to jack up both fronts or both rears at the same time
