I am installing slr mirrors on a car and I am trying to find the best way to tap into the turn signals. I have not taken the steering column off the cougar so I do not know if the two cars turn levers are similar. I have recently taken the plastic covering off of the steering column of my sis's 99 eclipse. There is four wires that run from the back of the turn signal lever to I am guessing a clip. Do these four wires run to the turn signal (two for each side) or is it most likely wires for the lights which are also connected to the lever (the kind you rotate at the very end to get the headlights to come on?) again I am asking as a general automotive question?
thanks
thanks
