Where's the best place to put the oil temp sender? The head looks like a good spot (under the TB) but I want to be sure it would give an accurate reading.
I'm also having some trouble with my water temp readings. The sender is currently tapped into the top coolant line that runs next to the battery towards the firewall. BUT I'm only getting readings of 40 to 60 degrees Celsius ( 104 to 122 F). Any ideas?
Thanks
Bridge
P.S YES the oil pressure AND Accusump are tied in behind the AC Compressor.... Barely
Picture of the water temp sender location
Thanks
Bridge
