Hey everyone,
Great forum, this is my first post and sadly it's about a problem I'm having with my car. I have a 2002 2.5 Duratec and it recently popped up a check engine light. I read the codes and it says fuel rail pressure sensor circuit malfunction.
Problem 1: So I located the fuel rail pressure sensor on the driver's side of the engine and started taking it off. Well, I got it all disconnected on the fuel rail side (only 2 bolts) and took the vac. line off, but I cannot figure out how to disconnect it from the fuel line! Can anyone tell me how to disconnect it from the fuel line?
Problem 2: I cannot find a new one anywhere. Does this part go by a different name or am I looking in the wrong places? Even the dealership didn't see anything in the computer called a fuel rail pressure sensor. Any help finding one?
Problem 3: Since the dealership had no idea what I was asking for, I decided to just put the car back together and drive it to the dealership and show them the part in person. Well, I placed the sensor back in place and tightened the 2 bolts down and it leaks! The car wouldn't even start! When I replace the sensor am I going to have to use some sort of sealant to keep it from leaking or is there a gasket or what? I didn't see any sealant or gasket when I took it off, so I thought I wouldn't need one.
I'm sorry this is so long, but I would very much appreciate any help.
Thanks a lot.
Thanks a lot.
