1 - 2 of 2 Posts
1999 Ford Cougar 2l I4
I currently have a Cougar with the 2 litre Zetec and the fuel pump is dead and i was wondering can the fuel pump from the V6 be used on the Zetec?
The part numbers for the fuel pump motor itself are the same between the two on Rock Auto's website. I don't think the entire sending unit assembly is interchangeable, but if you open it up and replace only the pump motor inside, you can use a V6 unit.
1 - 2 of 2 Posts
