I think I already know the solution to this but I dont want to replace the fuel filter or pump in the sub zero weather. Anyway, I have a 2000 v6 atx with 40,000 miles on it. Just the other day I went to pass someone and the car didnt want to go. It hessitated really bad until I let off the gas alittle. First thing I tried was some higher octane gas. This helped alittle but the hessitation was still there. So seeing as how it has been insanly cold outside I tried some gas line anti-freeze. Also seemed to help but it may just be in my head. The problem is still there. To my knowledge the filter and pump have never been replaced. Like I said I think I know what I need to do but I was hoping someone here may have some suggestions to hold me over till nicer weather.
Get the fuel filter replaced (or do it yourself - howtos are freely available in the How-To forum)... that should be a quick and easy repair that may be the cause of your problems.
Check if the symptom is occuring only when you have less than half a tank of gas. If so, it's a dirty sock on the fuel pump inside the tank. I've cleaned mine twice now, and it instantly resolves the problem.
Massiv.
Try the filter first like the other guy said, it takes like 15 min :)
I had some of the same problem then it went away when i changed the filter. I also had worse mileage too untill the filter change.
