Well, I'm kind of embarassed to be asking for help since I've been reading on this for a while. I got the kit, pads, rotors and went to do the driver's side this evening and just have a question..
It says to drill a 1/2 passage through EACH holes on the stock spindle. The spindle holes that use to support the caliper bracket in OEM form. Well, the bolts that go through the adapter plate and mounts in the OEM stock spindle holes fit perfectly, why cut them? I'm probably doing something wrong and need corrected but all directions I've seen are a lil shoddy.
This is what I'm looking at. I grinded the ear like it says and the spacer fits and lines up perfectly.
