1 - 2 of 2 Posts
Just locate the wire from behind the headunit and use the factory speaker wire. There is nothing wrong with the original wire. Otherwise you need to bypass the door harness thats in the jamb next to the hinge. That harness is not easy to remove and then get it back in securly.
1 - 2 of 2 Posts
