I have never seen a "fix" for this but I have always seen it asked a lot. Well if anyone cares it took me about 15 minutes to do it this morning. I recently got the Cougar WD off of eBay and after seeing what the relay looked like it took about two seconds to figure it out. All the relay is there for is to turn off the fogs when the high beams are activated. The reason for that is it is illegal to have more than four headlights on at once. Don't ask me why, that is NHTSA and DOT. So basically you just need to bypass the relay.
1. Just make a wire about 2" long with flat spade connectors at each end.
2. Remove the panel under the steering wheel. Two 7mm bolts.
3. To the left of the opening you will see the blue relay, pull it off of it's mount and remove the relay. To make sure you have the correct one, just turn on the fogs and flash
the highs. You will feel the relay click and it only has four pins.
4. Insert the wire you made into 3 and 5 of the connector. Look at the relay itself, these are the two wide flat pins and they are numbered.
5. Test, reassemble, test.
6. Enjoy!
I left all the lights on for about 20 minutes and there was not any sign of overheating or anything like that. The gauge of wire I used (16) was actually thicker than what goes into the connector itself (1mm or about 18 gauge) and it is only 12v.
6. Enjoy!
