In the May issue of SCC there was an article to figure out the maximum output a car can handle with the fuel injectors it has on it. It was pretty neat. This way you can prove all of those people wrong that say they have 400hp when it isn't possible with their set up. Here is the equation that they give:
Max hp= [injector flow rate]x[number of injectors]x[duty cycle] all divided by Brake Specific Fuel Consumption (BSFC)
-Ok we have 6 injectors (1 per cylinder)
-duty cycle is pretty much usually 85% (it is how much the injector is open and spraying fuel; so it would be open 85% of the time)
-BSFC for naturally aspirated engines are from .45 to .55 so they say to use .5 as an average
What is our flow rate then so we can calculate this out and see how much hp our duratecs can handle before they are pushing to much for the engine to handle?
Oh and of course this is crank hp because it would be too hard to figure out all of the variables for driveline loss into an equation.
