I have to put a new water pipe in the engine valley. This is the pipe that is sticking straight up in the valley near the rear of the engine, and a hose comes off this with a sharp nearly 180* elbow, and into the water pump...
I assume it is installed with locktite. Should I use blue or red loctite? When I install it, should I just bang it in with a rubber mallet or block of wood and hammer?
