I have an electric oil pressure gauge to be installed ASAP. I need to know if i need to use the sender or if i can just tap a signal wire. The Install seems to be quite easy once I locate the wire, if that is possable. Over on CEG, there is a huge debate as to the best location for the sender, for those that have oil pressure gauges already installed how did you do it?
Thanks
Thanks
