Ok This Has to be the Easiest way to do this. No Lines, pressure fittings, or leaks! The 2 Pictures explain themselves so open them up and expand them the whole way...
Ohh Yeah and this is an Autometer Phantom Gauge...U must use the extra fitting that comes with the sending unit to screw it in the block...And Use Teflon Putty, NOT tape. You can buy this at any parts store (I got mine at NAPA) Just tell them what you need it for and they will give you the right stuff.. And when you bend that metal PVC pipe out, bend it a little then try the unit for fit, bend and try. DONT GO APE [censored] ON IT!!
