You probably don't want to hear this, but.....
you have to break the tabs off and glue the new one back up. I know this because I had to replace mine because it was cracking and the dealership changed it for me. But make sure that you use something better then superglue, cause now mine is not attached anymore. Leave it to ford to think of a design like that. If you take off the whole center console then you could probably grind off the ends of the plastic tabs that hold the boot in and give yourself a better chance to remount a new one. Good luck.
