Guest
·About a week after I had my headers installed, my check engine light went off. I took it back to Tuned Performance where they were installed and they plugged in a computer diagnostic thing and the errors were something like:
Error xxxx Bank 1 Lean
Error xxxx Bank 2 Lean
I don't know much about ODB-II or whatever, so i'm not sure if it's the MIL terminators that came with the headers, or if it's really lean. So i decided to get a superchip because it supposedly adds more fuel to the mixture. The chip was $325 installed which included 2 before and 2 after dynos. The dyno was done at a Dynolab Inc. Here are the results:
Sizz's Dyno
The dyno was done in 4th gear, about 65 degrees outside with a small fan blowing towards the front of the car.
The red graph is the worst run without the chip: 147.1HP & 145.6 ft/lbs torque
Blue is best run with superchip: 152.9HP & 145.6 ft/lbs torque
EDIT: The best run without the chip was about .8 more HP and the worst run with superchip was .4 less hp.
I was pretty disappointed because I have done quite a few mods which seems to only result in 12 HP over stock! Here's a list of performance mods:
KKM
Pro-Flow MAF
SCA CAI
MSDS Headers
Borla Split-rear Cat-back Exhaust
Anyways, I'm hoping that the lean error is true. After the dynos, tuned performance called superchips inc. and asked what's up. They said that the cougar originally runs rich, and that it's possible that their program leaned out the car more. They weren't sure but after the speed shop sends in all of the specs, they will look into it and see if a custom chip is needed. I'm going to the focus/probe dyno this sunday and will also get my air/fuel ratio(whats the correct term for this?) tested. If it turns out my car is lean, I'll pay the extra $125 for a custom burnt chip and re-dyno. If it isn't lean, I'm going to give up my quest for more horsepower. BTW, can't afford a supercharger, and don't like the idea of nitrous, so don't offer those ideas to me
As far as the butt-dyno goes, I noticed a great improvement with the headers. I can't tell the difference with the superchip. Good thing superchips inc. has a 30-day money-back guarantee. I'll keep you guys update.
-Sizz
Sizz's Dyno
KKM
Pro-Flow MAF
SCA CAI
MSDS Headers
-Sizz
